Post by Ward on Jun 11, 2019 6:35:21 GMT -6
ok . . . this video is a little bit sensational, but filled with fact. Makes for an interesting watch Also Unfortunately, the conspiracy theories end up being more true than the main stream media. www.mercola.com also has good facts about the effects of EMF radiation on health.
Post by ericn on Jun 11, 2019 7:09:52 GMT -6
The more we implement wireless as our primary data and communications network the more I worry from a security and quality perspective. I think back to my days of touring and dealing with multiple wireless and all the headaches that brought on. Add in all the construction for the hardwired infrastructure that we seam to need to rebuild for each of these upgrades and I wonder if it’s really worth it! Now I’ll admit living downtown in Sprints base multiplies this because nobody wants Sprint to suddenly be #1.
Post by svart on Jun 11, 2019 8:20:14 GMT -6
Well since I'm a RF engineer.. I didn't watch the videos but I know the arguments all too well and when folks hear that I deal with RF, they typically ask my opinion on the matter, and usually get pissy when I give it to them. Hint: People ask for the truth, but can't handle the truth because they really just want juicy conspiracy. Truth is boring. Facts are boring. Neither of which give you something to vent about and seem emotionally invested to others. There's one thing that folks fail to note.. I hear people use the argument "the radiation from these towers" all the time. The use of the term "radiation" is a misnomer when used in most of these arguments because they expect there are foreign/subatomic particles streaming from these tower emitters. This isn't particle emitting "radiation" like nuclear radiation. There are no neutrons, electrons, atom cores or gamma photons shooting out. And YES, there are tons of folks who believe this to be TRUE. The "emission" is stimulating the surrounding air to propagate a waveform, just like audio, but at much, much higher frequency. And much like audio, a lot of these systems use a technology called "waveguides" which are actually acoustic chambers and pipes to carry the signal. YES, they are hollow and YES a lot of the antennas are more like acoustical horns (waveguides) like you see on tweeters. Why? Because they work at higher powers that can't be easily dealt with on circuitboards, and the signal power losses over frequency through cabling are too great to use normal cables. You have less loss through the air at medium distances, so they use hollow conduits to get the signals from the machine rooms up to the tower transceivers, just like your ear canal pipes the sound from your outer ear to your eardrum. But the funny thing is all the soccer moms complaining at the local town hall about the new tower on their street don't realize that the "safest" place is actually closer to the tower, not further. The emitter beams are, of course, the width of the emitter face and then spread out with distance. If you're under the tower, you're usually outside of the beam and are only receiving incidental signal. You have two components of a signal itself that are significant factors in what people consider to be harmful.. Frequency and power. The frequency of cell signals, including the upcoming 5G is already filled with with existing radio emissions. See the chart I linked below to be ASTOUNDED by the amount of radio signals already present in the air that you probably had no idea were actually there.. The first 5G band is in the 3.5GHz range. Band 2 is in the 20GHz-300GHz range. This puts it between existing cell frequencies of around 2.4GHz, microwave ovens at around 2.42GHz and the very bottom of infrared light at around 300GHz. So if you think 5G will cause cancers due to frequency, then I have some bad news about infrared light and microwave ovens.. But fear not, the penetration ability of a waveform or particle drops drastically as you go up in frequency if you don't consider power. (BTW, look up perytons) Next is POWER. How much power are we talking? Well, nobody really knows what the optimal power output for 5G is yet since a real-world application criteria is not defined. 5G uses a new technology called MIMO which in layman's terms means that it's electrically directional. They use a panel of smaller antennas and adjust phase relationships between all the antennas to "steer" the signal towards the cell phone so that it's more focused rather than just beaming out everywhere. That makes a HUGE difference in how you measure power output, but 5G frequencies also mean that the signal travels a much shorter distance and does not propagate around corners or through barriers like walls, so they'll need a lot more stations to fill in the gaps. But to generalize, most stations are starting up around 30-40dBm which in real-world numbers is about 20W of power directly in front of the transmitter. That's it. 20 watts. The computer screen you're staring at is outputting about that towards your eyeballs. Now you have eye cancer to go with your brain cancer that your cell phone gave you. /sacrasm.. Your cell right now can output about 1W at peak, but generally around 200mW. 200mW right up next to your skin at around 2.4GHz equals a depth up to around 1mm. The dead skin layer on your epidermis is slightly less than that. They also figured that a full power transmitter would raise the skin temperature about 1 degree Kelvin. Considering you're getting broadband radiation (in these frequencies, mind you) from the sun at around 500W/M^2, kinda seems inconsequential, doesn't it? Most of the studies on frequencies and power have fatal flaws. Most use monotonic carrier waveforms, not highly modulated signals which spread power across wider frequencies and greatly lessen the impact at a single point (much like you focus the sun through a lens to start a fire). Most also use much higher than average powers and crest factors in order to actually elicit biologic responses in order to measure "something". upload.wikimedia.org/wikipedia/commons/c/c7/United_States_Frequency_Allocations_Chart_2016_-_The_Radio_Spectrum.pdf
Post by ragan on Jun 11, 2019 10:09:45 GMT -6
Frankly, I’m more concerned about wind cancer myself. Scary stuff.
Post by Blackdawg on Jun 11, 2019 10:18:29 GMT -6
lol radio waves are gonna kill us alllll!! RUN FOR YOUR LIVES!!!!! ridiculous. Great read svart enjoyed that. Im a Ham radio operator, so I know a little about radio waves and things. It is hilarious how much RF there is in the world that people just don't know about and blame random shit on. Funny stuff.
Post by svart on Jun 11, 2019 10:18:54 GMT -6
Frankly, I’m more concerned about wind cancer myself. Scary stuff. Wind turbine cancer. Serious stuff.
Post by svart on Jun 11, 2019 10:25:12 GMT -6
lol radio waves are gonna kill us alllll!! RUN FOR YOUR LIVES!!!!! ridiculous. Great read svart enjoyed that. Im a Ham radio operator, so I know a little about radio waves and things. It is hilarious how much RF there is in the world that people just don't know about and blame random shit on. Funny stuff. People have a habit of blaming their own problems on things they can't control, with the benefit of knowing there isn't much they can do about those things. It absolves them of responsibility to find solutions to their own problems and gives them things to virtue signal over. Unfortunately it's usually based on ignorance on their part, as well as the ignorance of those around them.
Post by christopher on Jun 11, 2019 10:54:26 GMT -6
too sensational. But what I find hard to argue against militarized frequencies as a weapon. That seems legit, and so does his explanation of targeted low-level microwave dosing over the span of years to induce illness and cancers. I feel if I had money I could build a weapon easily to get it done, so I'm sure governments figured that one out. And if we have the means to put the transmitters anywhere and everywhere, its just a matter of having access at the top of these tech companies to take control of any transmitter.
But if someone makes a radiation detector that can be worn at all times, it will be easy to check and figure out what's going on. Especially if it tells you the long-term safe doses and whether you are over that long term limit or not. As we move along, that might just be just a nice thing to have, just to keep track in the sunlight or flying or whatever. Hmm.
Post by Blackdawg on Jun 11, 2019 10:56:50 GMT -6
too sensational. But what I find hard to argue against militarized frequencies as a weapon. That seems legit, and so does his explanation of targeted low-level microwave dosing over the span of years to induce illness and cancers. I feel if I had money I could build a weapon easily to get it done, so I'm sure governments figured that one out. And if we have the means to put the transmitters anywhere and everywhere, its just a matter of having access at the top of these tech companies to take control of any transmitter. But if someone makes a radiation detector that can be worn at all times, it will be easy to check and figure out what's going on. Especially if it tells you the long term safe doses and whether you are over that limit or now. Why? RF is not radiation.. There's probably a higher risk of getting skin cancer just from the sun than from a microwave.
Post by christopher on Jun 11, 2019 10:57:21 GMT -6
think of the food inside the microwave
Post by svart on Jun 11, 2019 11:02:26 GMT -6
too sensational. But what I find hard to argue against militarized frequencies as a weapon. That seems legit, and so does his explanation of targeted low-level microwave dosing over the span of years to induce illness and cancers. I feel if I had money I could build a weapon easily to get it done, so I'm sure governments figured that one out. And if we have the means to put the transmitters anywhere and everywhere, its just a matter of having access at the top of these tech companies to take control of any transmitter. But if someone makes a radiation detector that can be worn at all times, it will be easy to check and figure out what's going on. Especially if it tells you the long-term safe doses and whether you are over that long term limit or not. As we move along, that might just be just a nice thing to have, just to keep track in the sunlight or flying or whatever. Hmm. The military has experimented with area denial via infrasound and ultrasound, etc. The problem is that the power required for infrasound is too great to be feasable and ultrasound loses too much energy through the air to be useful more than a few hundred feet. And yes, there are RF detectors, called spectrum analyzers and RF power meters.
Post by christopher on Jun 11, 2019 11:02:35 GMT -6
Oh I see.. radiation detector.. oops. I'll have to ponder that one. How do we know what RF is hitting us and effects? Yeah the technicals are definitely over my head, I'd have to learn the specifics about this stuff. I don't think its discounts the military aspects?
However.. 5G isn't really about warfare, its about money. MONEY MONEY money money. The warfare is just one sales aspect and a means to get investors to buy in at all costs. (See we can make life easier AND give rich people ability to toy with your enemies! If you don't invest, your enemies will!) ---
edit: HAHA.. this stuff is crazy to think about! Is 5G really going to be able to get a 3D scan of the environment? It seems like the next step after big-data. They already track every single thing we do, but its only where we have our phone. (not sure why they care so much)..
Is 5G going to allow 3D tracking in a scanned environment?
Or put another way.. will we soon be able to snapchat filter a Neve console onto our table?
Post by svart on Jun 11, 2019 11:14:34 GMT -6
think of the food inside the microwave I'm unsure of what you mean.. Microwave ovens excite water molecules by vibrating them with waves of large amounts of power, like 1000W or more by bombarding them with photons. it's a fundamentally different concept than e-mag emissions from telecommunications. Also, unlike popular misconceptions, the food does not cook from the inside out, it cooks from the outside inwards because the photons cannot penetrate more than a few millimeters even at such high power levels. It's the constant application of this power that results in heating of the external water molecules that transfers that heat inwards to the core of the food. The frequency, 2.42-2.45GHz (for consumer level microwaves) and 915MHz (for commercial microwaves) were simply chosen because at the time of the conception of the microwave oven (in the 1940's) these were open frequency bands that were not being utilized.
Post by christopher on Jun 11, 2019 11:15:16 GMT -6
RF power meters.. ok. We need to bundle that and a radiation detector into a phone case. Then we market it to the parents out there, it keeps life-long track of their kid's exposures
Post by Tbone81 on Jun 11, 2019 11:16:05 GMT -6
These discussions get murky because words like “radiation” are pretty broad terms. In a general sense, tons of things are radiation. The heat coming from your furnace is radiation. It’s thermal energy “radiating” from your ducts. It’s radiant heat.
When people speak of the harms of radiation however, they’re talking (knowingly or unknowingly) about ionizing radiation. Which is electromagnetic (or nuclear/sub atomic) radiation that has the strength to disrupt electrons and/or nuclei of atoms. This is the harmful radiation that causes sickness, cancer etc.
As to exposure, It’s commonly said that there is no safe level of ionizing radiation exposure...however that too is a misconception. Harmful exposure is a factor of 1) strength of exposure 2) length of time of exposure and 3) frequency of exposure (as in how many times you’ve been exposed).
What would surprise most people to learn is that everyday were exposed to naturally occurring ionizing radiation. Some of it is background radiation coming from cosmic X-rays bombarding our planet. Some of it comes from minerals and heavy metals in the soil, like argon that is off put from granite. Ever take a swim in a natural hot springs? Guess what...more radiation! Mostly this is all harmless though and doesn’t decrease your life expectancy any more than breathing polluted air, or drinking tap water etc.
Post by christopher on Jun 11, 2019 11:17:56 GMT -6
Microwave ovens excite water molecules by vibrating them with waves of large amounts of power, like 1000W or more by bombarding them with photons. it's a fundamentally different concept than e-mag emissions from telecommunications. Also, unlike popular misconceptions, the food does not cook from the inside out, it cooks from the outside inwards because the photons cannot penetrate more than a few millimeters even at such high power levels. It's the constant application of this power that results in heating of the external water molecules that transfers that heat inwards to the core of the food. The frequency, 2.42-2.45GHz (for consumer level microwaves) and 915MHz (for commercial microwaves) were simply chosen because at the time of the conception of the microwave oven (in the 1940's) these were open frequency bands that were not being utilized. that is the exact knowledge I was missing! Wow, very informative.
Post by christopher on Jun 11, 2019 11:21:54 GMT -6
These discussions get murky because words like “radiation” are pretty broad terms. In a general sense, tons of things are radiation. The heat coming from your furnace is radiation. It’s thermal energy “radiating” from your ducts. It’s radiant heat. When people speak of the harms of radiation however, they’re talking (knowingly or unknowingly) about ionizing radiation. Which is electromagnetic (or nuclear/sub atomic) radiation that has the strength to disrupt electrons and/or nuclei of atoms. This is the harmful radiation that causes sickness, cancer etc. As to exposure, It’s commonly said that there is no safe level of ionizing radiation exposure...however that too is a misconception. Harmful exposure is a factor of 1) strength of exposure 2) length of time of exposure and 3) frequency of exposure (as in how many times you’ve been exposed). What would surprise most people to learn is that everyday were exposed to naturally occurring ionizing radiation. Some of it is background radiation coming from cosmic X-rays bombarding our planet. Some of it comes from minerals and heavy metals in the soil, like argon that is off put from granite. Ever take a swim in a natural hot springs? Guess what...more radiation! Mostly this is all harmless though and doesn’t decrease your life expectancy any more than breathing polluted air, or drinking tap water etc. This website will put a lot of people at ease: www.radiationnetwork.com/index.htmwww.radiationnetwork.com/DetailMaps.htmIf you check in for a few weeks, it gets boring fast. We shouldn't ever have to worry about this, but in our lifetime or our children's lifetime, there's enough idiots doing stuff in secret..
Post by Tbone81 on Jun 11, 2019 11:23:08 GMT -6
Weaponizing any form of energy or radiation is whole different topic. And quite fascinating too! The technology used for energy weapons is crazy and mind blowing, and we, the general public have very little understanding of it.
But in broad terms, yes you can take otherwise harmless forms of energy and turn them into weapons. That includes visible light (lasers), acoustic energy (saser and directed sound waves), microwaves etc.
All of that is really beyond the scope of these commercial applications that we’re talking about (5g, microwave ovens etc)
Post by svart on Jun 11, 2019 11:23:29 GMT -6
Oh I see.. radiation detector.. oops. I'll have to ponder that one. How do we know what RF is hitting us and effects? Yeah the technicals are definitely over my head, I'd have to learn the specifics about this stuff. I don't think its discounts the military aspects? However.. 5G isn't really about warfare, its about money. MONEY MONEY money money. The warfare is just one sales aspect and a means to get investors to buy in at all costs. (See we can make life easier AND give rich people ability to toy with your enemies! If you don't invest, your enemies will!) --- edit: HAHA.. this stuff is crazy to think about! Is 5G really going to be able to get a 3D scan of the environment? It seems like the next step after big-data. They already track every single thing we do, but its only where we have our phone. (not sure why they care so much).. Is 5G going to allow 3D tracking in a scanned environment? Or put another way.. will we soon be able to snapchat filter a Neve console onto our table? The military already has a lot of communications networking of it's own. It doesn't need 5G. A large majority of satellites in orbit are government-only communications satellites.. A lot of their fiber backbone is completely separate and redundant to the consumer backbone. I used to work for Bellsouth many years ago and I'll tell you, there are some eye-opening things going on in government communications that the public has NO idea about and is probably happier not knowing. 5G and a lot of existing comms protocols have the ability to capture data on multi-path delays in MIMO. As the transmitter and receiver handshake, the transmitter will scan for greatest signal strength to steer the signal towards the receiver. During this time you could theoretically capture a lot of data on delay times which could work out to rough estimates of distances to objects that produce phased reflections, AKA: produce a rough sonar image. But it's already being done. Your WIFI routers with the bundle of 4-or-more antennas on top? Those antennas are a phased array that steer the signals just like 5G will. In fact, there are concerns that hackers are already using the routers for mapping, etc.
Post by Tbone81 on Jun 11, 2019 11:29:14 GMT -6
Damn, that’s crazy Svart.
Yeah I think hackers, and our general reliance on electronic “things” is a greater threat than radiation. Hell, with out gps my daughter wouldn’t know how to find her way around...neither would my wife. I just taught my daughter how to use a pay phone because she had never seen one before...that shit is scary!
Post by svart on Jun 11, 2019 11:36:31 GMT -6
RF power meters.. ok. We need to bundle that and a radiation detector into a phone case. Then we market it to the parents out there, it keeps life-long track of their kid's exposures Even with ionizing radiation (the types from nuclear fission), you can take quite a bit without ever having an issue. The less powerful radiations like Alpha and Beta radiation can barely penetrate the skin. Simply washing and lightly scrubbing your skin can cleanse yourself from the particles. It's when they get places you can't clean, like your lungs when you breathe in radioactive dusts, that they do their damage by radiating the surrounding soft tissues over time and causing random DNA damage. Most cells just die when their DNA is broken through radiation, but some have their DNA broken in ways that don't kill the cell outright and they can sometimes divide into multiple cells that have no control over their replication, resulting in cancers. Higher power radiation types like Xrays and Gamma are able to zip right through your body and can damage much higher numbers of cells just from external exposure. The issue with broad statements about lifetime exposure is that generally there is no clear delineation between tolerable amounts of low-level exposure and untolerable amounts. It's very different from person to person, and exposure situation. A person who is exposed to higher levels for shorter periods is generally less likely to develop cancers because the higher radiation doses tend to kill the cells outright. However, it depends greatly on the type of radiation, the location of exposure, etc. If you want a laugh though, go check out the "banana equivalent dose"..
Post by Blackdawg on Jun 11, 2019 13:51:09 GMT -6
Oh I see.. radiation detector.. oops. I'll have to ponder that one. How do we know what RF is hitting us and effects? Yeah the technicals are definitely over my head, I'd have to learn the specifics about this stuff. I don't think its discounts the military aspects? However.. 5G isn't really about warfare, its about money. MONEY MONEY money money. The warfare is just one sales aspect and a means to get investors to buy in at all costs. (See we can make life easier AND give rich people ability to toy with your enemies! If you don't invest, your enemies will!) --- edit: HAHA.. this stuff is crazy to think about! Is 5G really going to be able to get a 3D scan of the environment? It seems like the next step after big-data. They already track every single thing we do, but its only where we have our phone. (not sure why they care so much).. Is 5G going to allow 3D tracking in a scanned environment? Or put another way.. will we soon be able to snapchat filter a Neve console onto our table? The military already has a lot of communications networking of it's own. It doesn't need 5G. A large majority of satellites in orbit are government-only communications satellites.. A lot of their fiber backbone is completely separate and redundant to the consumer backbone. I used to work for Bellsouth many years ago and I'll tell you, there are some eye-opening things going on in government communications that the public has NO idea about and is probably happier not knowing. 5G and a lot of existing comms protocols have the ability to capture data on multi-path delays in MIMO. As the transmitter and receiver handshake, the transmitter will scan for greatest signal strength to steer the signal towards the receiver. During this time you could theoretically capture a lot of data on delay times which could work out to rough estimates of distances to objects that produce phased reflections, AKA: produce a rough sonar image. But it's already being done. Your WIFI routers with the bundle of 4-or-more antennas on top? Those antennas are a phased array that steer the signals just like 5G will. In fact, there are concerns that hackers are already using the routers for mapping, etc. What crazy is radio is still the most secure form of communication. Lots of different coding happening via radio that countries all around the world use for secret messaging.
Post by ragan on Jun 11, 2019 14:40:56 GMT -6
Also, if anyone wants to get a better understanding of this stuff, stay out of the conspiracy theory echo chambers and just grab a physics book. Get an old edition that’s dirt cheap and start reading about waves. You can’t really understand it unless you start at the bottom (in my experience anyway). If the math is confusing, get going on Khan academy. I’m totally serious. Real knowledge about this stuff is there for the taking but you’ll have to earn it.
I’m a long, long ways from an expert but I’m far enough along now to know that you can’t really ‘casually’ understand this stuff.
Post by johneppstein on Jun 11, 2019 15:54:38 GMT -6
too sensational. But what I find hard to argue against militarized frequencies as a weapon. That seems legit, and so does his explanation of targeted low-level microwave dosing over the span of years to induce illness and cancers. I feel if I had money I could build a weapon easily to get it done, so I'm sure governments figured that one out. And if we have the means to put the transmitters anywhere and everywhere, its just a matter of having access at the top of these tech companies to take control of any transmitter. But if someone makes a radiation detector that can be worn at all times, it will be easy to check and figure out what's going on. Especially if it tells you the long-term safe doses and whether you are over that long term limit or not. As we move along, that might just be just a nice thing to have, just to keep track in the sunlight or flying or whatever. Hmm. Er, no. Didn't you catch the bit about the "radiation" from cell phones not being the same kind of thing as atomic radiation?
A "radiation detector" like they wear in atomic facilities wouldn't register anything if you rammed it right down the throat of a cell tower antenna array. Nada. Zip.
Cell phone "radiation" is just a radio signal. It's not particle radiation or ionizing radiation, like you get from radioactive elements. It's waves radiated through the atmosphere/space, essentially all it is is a particular frequency range of modulated light.
A detector for such radiation is pretty trivial - all it would be would be a radio receiver of the desired bandwidth connected to a meter or metereed recorder, like a pen graph or digital equivalent. But it would be pretty pointless.
Post by christopher on Jun 11, 2019 15:56:05 GMT -6
I love learning about this stuff to a degree. Electro magnetic waves (light) are so weird, nobody can say for certain what it is. The classic model is sort of easy to understand, but it makes no sense with reality. The new proposed models make sense, but its pushed back against the ones who know the classic model. Stuff like that kind of ruin it for me. What's really the real truth?
